Hi Guys,
I have recently purchased a Salus RT500RF wireless thermostat to connect to my Ideal Vogue boiler as we currently have no stat at all and I am unsure on a couple of things on fitting the transmitter to the boiler.
There is a single socket I can take a feed from to create a fused spur and then run live and neutral from that to the transmitter for permanent supply but I am unsure how to connect the transmitter to the boiler?
The thermostat can be installed for 24v and 230v installation although I am unsure which one is correct for my boiler as it does not stipulate this in the manual and I don't fancy blowing the PCB.
Transmitter has live, neutral, com (linked live feed for 230v) and N/O (normally open).
Also what cable is sufficient for both parts?
Thanks in advance.
Thanks in advance.
