I am installing a wall mounted bath filler and want to know if I should not cut a hole into the breeze block to make space for it.
I have around 45mm of space between the aqua panel face and the breeze block, but some of the taps need more like a 70mm + of space. The tap are located under a window so there are no structural issues I assume? I also would only be breaking through into the void of the block (These are the blocks with 2 large circular voids running through them, just in case there are different types!
) So, I will not break though the entire block into the void between block and brick.
What you all reckon? Bad? Ok?
Thanks!
Thanks!
