Ok, so I'm doing up the bathroom and decided I wanted wall mounted taps.
I didn't consider when buying them that they would need space behind the tiled surface! In total the taps need about 3.5inches. The wall is 3/4inch batons on top of breeze block.
So I am thinking that when I put the plasterboard up on that wall I will stud it out to 2 inches so I will still need 2 inches say. Is it ok to take 2 inches away from the breeze block with a chisel? Then a Chanel down to under the bath level to bring pipe work out?
Hopefully this makes sense!
Darren
Darren
