HI, HOPE SOMEONE OUT THERE CAN HELP ME!
I am in the process of installing a pair of deck valves which connect to a single outlet in the bath filler. Given that the outlet is a single outlet i need to combine the hot and the cold feed together.
Can i join them together anywhere between the tap and the bath outlet? and what size pipe would you use?
Thanks in advance for your help
Bingo
Bingo
