    Dismiss Notice
Insulate sloping ceilings
Discussion in 'Roofing and Guttering' started by selfbuildextension, 26 Nov 2018.
  1. selfbuildextension
    selfbuildextension
    12 Oct 2018
    75
    Thanks Received:
    Glasgow
    Country:
    My upstairs bedrooms all feature a 1.5m section of sloping ceiling from the outside wall before turning to a normal flat ceiling. It's a 1930's semi and i presume there is no insulation between the sloping ceiling and the roof. This section of ceiling is much colder to touch. I am going to lay new insulation in the loft, but how do i deal with the sloped part?
    The ceilings are covered in cracks so no issues stripping them but I don't want to introduce any condensation/damp issue.
  2. Sponsored Links
  3. Alastairreid
    Alastairreid
    21 Nov 2008
    6,613
    Thanks Received:
    1,072
    uk
    Country:
    You can use insulated plasterboard fixed to the existing ceiling, or remove the lath and plaster and insulate between the rafters.
  4. noseall
    noseall
    2 Feb 2006
    42,257
    Thanks Received:
    2,630
    Staffordshire
    Country:
    Do both or you risk rafter 'shadowing' occurring. Make sure there is an air gap above the insulation (cold side) if you do decide to go between the rafters and robustly introduce vapour control measures.
  5. selfbuildextension
    selfbuildextension
    12 Oct 2018
    75
    Thanks Received:
    Glasgow
    Country:
    Thanks for the replies.
    So I could batten to leave a gap and put as thick as possible insulation between rafters then insulated plasterboard fixed to the rafters and skimmed.
    Would I put a vapour control membrane after the rafter insulation but before the insulated plasterboard?
    Thanks,
    Shaun
  6. catlad
    catlad
    29 Jul 2011
    4,715
    Thanks Received:
    713
    Lancashire
    Country:
    Once you have fitted the kingspan between the rafters you can buy 100mm foil tape or staple a vapour barrier
    to the rafters prior to insulated plasterboard.
  7. noseall
    noseall
    2 Feb 2006
    42,257
    Thanks Received:
    2,630
    Staffordshire
    Country:
    You are much better off installing them as separates - i.e. fix a sheet of insulation across the rafters then a sheet of plasterboard. It means you can use foil sandwich Celotex type insulation board which can be foil taped. You can then use foil backed plasterboards.
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
