Insulated loft door to fit 630x615mm opening?
9 Feb 2008
Hampshire
Hi all
I'm just finishing insulating my loft and the final job is to sort the loft access door. The current setup is a wooden opening which has been converted at some point so the door is on hinges and opens with a catch.
However there are gaps around the edge which will let past a significant amount of warm air from below and this will entirely defeat the purpose.
I'd like to fit a modern plastic, insulated hatch but all the ones I look at are fitting size 561 x 726mm and the current opening to my loft is around 630x615mm.
Does anyone know where I can get some other sizes for loft hatches? It needs to be an insulated hatch with a drop down door so I can continue using my loft ladder.
Many thanks
