    Dismiss Notice
Insulated plasterboard on an internal sloping ceiiing
Discussion in 'Roofing and Guttering' started by RichTraff, 12 Dec 2013.
  1. RichTraff
    RichTraff
    12 Dec 2013
    58
    Thanks Received:
    Lancashire
    Country:
    I'm insulating, plaster-boarding and skimming the sloping roof ceilings in my bedrooms. It's only a small area where its sloping but I'd still like to hav insulations.
    I am aware of the 50mm air-gap recommend in the joist to allow for proper ventilation.
    My dads plan is cut kingspan or their equivilant and slot the inbetween the rafters. Allowing a 25mm air gap and then boardboard plasterboard over the top.
    Personally i think it's risk, and believe its easier (if not more expensive) to buy special insulated kingspan plasterboard and scew it straight to the rafter. :eek:
  2. Sponsored Links
  3. catlad
    catlad
    29 Jul 2011
    4,659
    Thanks Received:
    701
    Lancashire
    Country:
    I would do it your way.
  4. tony1851
    tony1851
    23 Feb 2012
    10,096
    Thanks Received:
    1,526
    Manchester
    Country:
  5. Alastairreid
    Alastairreid
    21 Nov 2008
    6,566
    Thanks Received:
    1,059
    uk
    Country:
  6. freddiemercurystwin
    freddiemercurystwin
    21 Jan 2007
    19,433
    Thanks Received:
    2,173
    Devon
    Country:
  7. Sponsored Links
  8. tony1851
    tony1851
    23 Feb 2012
    10,096
    Thanks Received:
    1,526
    Manchester
    Country:
  9. noseall
    noseall
    2 Feb 2006
    41,884
    Thanks Received:
    2,614
    Staffordshire
    Country:
    +4's look daft on golfers.
  10. RichTraff
    RichTraff
    12 Dec 2013
    58
    Thanks Received:
    Lancashire
    Country:
    Eh?
    So insulted plasterboard straight to the rafters.
    How about this though....
    Screw 50mm kingspan onto the rafters, then screwed plasterboard over the top?
    The materials would be cheaper this way.
  11. noseall
    noseall
    2 Feb 2006
    41,884
    Thanks Received:
    2,614
    Staffordshire
    Country:
    Equally as good a method if not better. We often do it this way and means that you don't have to cut the insulation boards (joints) onto any rafters, which in turn means less waste.
  12. RichTraff
    RichTraff
    12 Dec 2013
    58
    Thanks Received:
    Lancashire
    Country:
    Excellent.
    That is what I'll do.
    Thanks for the replies.
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
