I am currently redecorating my living room which will involve the whole room being skimmed. I'm considering putting insulated plasterboard on the two external walls.
It's a 60's bungalow with a cavity wall that's been insulated at a later date (loose fill fiberglass type insulation.) Last winter there did seem to be some cold spots in the room on the external walls.
Is it just a case of sticking the boards on the wall with something like pinkgrip dry fix? Is there anything else I should consider before doing this?
Could I hide radiator pipes beind the plasterboard by removing a small vertical channel of the insulation, or would this create problems?
