I realise that garage insulation questions are pretty common on here, but I'm more interested in asking whether or not it's worth me doing rather than how to do it.
I've got a brick-built detached (1978) house with an attached garage of the same construction (also pitched roof) but single-skin walls all around including the wall adjoining the house. It's got a concrete floor and a steel up-and-over door.
The interior walls are all bare brick but the ceiling has been boarded and skimmed. I'm presuming that the 'loft' space above hasn't been insulated but I'd need to cut an access hole in order to check for sure.
My question is, am I likely to notice much difference, in terms of heat lost from the house and heat lost from the garage itself, just by fixing 50mm Celotex to the inside of the garage door and then fixing Celotex insulated plasterboard to the wall adjoining the house?
I'm concerned that as it stands, the garage is acting like a massive heatsink and leeching warmth from the house and then to the outside air via the garage door.
