Hey All,
I am buying this:
http://www.gardenbuildingsdirect.co.uk/Wooden-Sheds/BillyOh-4000L-Kent-Tongue-and-Groove-Garden-Shed
Or something very similar to it.
At the moment there is a concrete base at the bottom of the garden (previous owner had a shed and green house down there) which is 11ft x 6ft. I intend to dig out a bit to make it wider and create a base using cinder blocks seeing as I have loads.
To insulate the shed I was going to run extra battons on the inside and put in something like celotex. What should I cover this with - wood (OSB?) or plasterboard? I don't intend to have it plastered inside, just a few coats of paint. What about the roof - I was going to run battons again and clad it internally with either wood or plasterboard depending on advice.
I have a load of attic insulation (I have about 10 spare rolls) could I use this instead of celotex?
What about the floor? What options do I have here?
Also I was thinking of going to a local window supply store and getting some double-glazed windows (which can be opened). Is this doable?
Basically I am looking to create an office as I have no space in the house. I looked at getting a log cabin but I would still have to insulate so I figured a cheap shed and adding the insulation costs would be cheaper. My brother in law is an electrician and has agreed to run the electrics down to the shed once it's installed.
Any advice appreciated
I am buying this:
