Hope one of you knowledgable guys on here can help me. The previous owners of our house built a small porch on to the front of the house to extend the small downstairs hallway. The porch itself is roughly 2x1m and there is no door between it and the downstairs hall (previous front door has been taken out).
The porch is making the downstairs of the house extremely cold due to it only being made of a single layer of bricks and having no insultation to speak of whatsoever. There isn't even any plasterboard on the brick, just some textured compound that has been painted over.
I soon want to begin work to rectify this problem and want to know what the best course of action would be to insulate the porch to make the house warmer and eliminate the build up of condensation on the exterior walls of the porch which is encouraging mould growth.
Would it just be a case of putting up a polythene membrane over the walls, then battening and fitting foil backed plasterboard with some other insulation (rockwool for example) in between the batterns. Then sealing the plasterboard prior to plastering or are there additional things I should be doing?
There are also several holes drilled in the mortar that go through to the outside - these are covered with ventilation plates on the inside. Will I need to keep these (obviously doing them in a more aesthetically pleasing way) or can I do away with them altogether?
Many thanks in advance for your help - I should be able to post photos up if it helps at all.
