insulating an outhouse brick shed
4 Feb 2009
Buckinghamshire
hubby uses the out house as a little office to build and sell computers can anyone advise on a cheap way of insulating it please?
many thanks
You can batten the wall out, insulate, vapour check and board out, then plaster finish. There are few varrious methods of doing this.
You can also batten out and board out using materials such as thermaline boards or K18, again plaster finish.
links
http://www.british-gypsum.com/produ...es/gyproc_thermal/gyproc_thermaline_plus.aspx
http://www.insulation.kingspan.com/uk/pdf/k18.pdf
You could save costs by using rock or mineral wool to insulate and using a type of Visqueen Vapour Control Layer, will also save cost against using foil back boards but I personally prefer to use the foil back/duplex boards.
