Insulating conservatory roof
8 Nov 2004
Hi all I'm thinking of insulating my conservatory roof. Is it possible to screw battens to the plastic either side of the poly carbonate sheets?
The plan is to batten them then out insulation against the sheets then cover that with some sort of cladding. What sorry of insulation should I use please also what sort of cladding could I use to cover it. Thanks in advance.
I wonder if anyone could advise how far into the plastic supports I can screw to hold the battens please
You could screw battens etc but I seriously advise against it , yes I know plenty of people have done it but please reas my reasonings why ...
Firstly, if you get that position wrong you will hit the drainage channel ( imagine the bar is an upside down T , you hit the horizontal parts of the T and you are in the drainage channel) , and any water getting past the rubber seals will be rusting that screw an potentially leaking.
Secondly beware insulation you use. It WILL get wet due to condensation over a period of time ( especially at the lower end of the conservatory)
Thirdly- see above , you will get mould on the internal.face of the roof sheets you have covered , and on the back of any boards you put up without suitable ventilation
Fourthly, beware how much extra weight you are applying the structure
Fifthly , if the roof sheets get damaged by hail ( older roof sheets in particular get brittle so its quite common ) or the roof develops any leaks you are not going to see it for a while
Honestly I have removed enough ' internal cladding ' on conservatories to see the issues listed above . I understand why people do it but I really wouldn't and if I was looking at a new house with it i' be asking for money pff because of it. Yes there are companies that advertise it and again I wouldn't do it and can just see the issues ' down the line '
Other alternatives are
Warmcore roofs -completely new insulated tiled roof
' Heatshield ' Polycarbonate - direct replacement but still noisy when it rains or
Insulated Roof panels - again direct replacement but NOT the same panels as used in doors ( have seen these used and they are awful and dont last ). The proper panels are made in Germany and can come with an accoustic interlayer too. Much quieter than polycarb and much better insulation ( depending on where you are in the country I potentially could say who to ask for these... and no I get no commission so not an advert! )
Really appreciate your reply and I have actually thought about most of what you said and accept there is a risk, which is why I asked the question hoping that people who have done it successfully might guide me through the problems. Thanks for the reply though.
If you are intent doing it , it is possible . as ive said there are companies out there doing it. Main point is hitting the centre of the roof bar with your screws, and then not too long they go right through the bar
As goes an internal material, thin ply or 300mm pvc hollow soffit board
Thanks again, is it as simple as measuring the width and just marking the centre? I've seen 1"battens used but wondered if 1/2" would be ok so add not to come too far down, any idea what length of screw would be best?
Yes it should be as simple as measuring to the centre. Length of screws? Enough to go through your batten and catch the metal securely. If you go outside, look at one of your roof supports/bars , you maybe able to unclipped or unscrew one of the bar ' end caps ' , this will show you the profile of the bar and give you an idea where to screw and how long the screws can be
this is the end of one where would I be trying to place the screw please?
looks like a wendland roof bar ( as above ) , your going to struggle to get central I'm afraid , as its really thin
The two side bits ( orange marks on your picture) are the drainage channel for if any water gets past the gaskets, you really don't want to be in those .
Having said that you could , potentially ( and personally I'm not advising this ), drill into the channel at the top of the " slope ' , so as close to centre as possible , and make sure the screws are ' sealed ' as you screw in. The obvious thing is its a potential for a leak if lots of water gets in hence I really cant recommend it as a way of doing it... that decision is yours alone and being made well aware its a potential leak point. I do not want to be held potientially iable for any future leaks hence I'm advising against doing it
