Hi we had an extension done over our garage few years ago. The bedroom above the garage is always freezing cold only warms up when we put an extra electric heater on which is very costly.
someone suggested to me that the garage ceiling needed to be properly insulated.
I know our ceiling was never insulated properly as our builder always took short cuts, he put small amount of rockwool in the ceiling.
It has been suggested that i should get insulation boards up which will prevent the cold rising from the garage into the bedroom. I dont mind having that done as long as it stops the cold.
My question is: will the insulation boards stop the cold rising up into the bedroom.
which insulation boards are best to use.
The garage ceiling is plastered so will the plaster need to be removed or can
the boards be placed over the plaster and replastered.
Thanking you in advance any advice will be appreciated.
