I'm new to this forum, and I didn't see this exact question asked in a search. If it's already been posted, please point me in the right direction. I've recently bought my first house, and the loft insulation is well below recommended depths. It's only about 1 inch thick! So I wish to get it properly insulated before this winter.
The building is built in the 70s and has a fairly low roof, and the joists and rafters are both 100mm deep. I would like to use the loft space for storage primarily - it will not be a livable area. I would like to install loft boards in the central area, where I'd like to be able to walk in order to store things up there.
The issue I have is that if I install lots of insulation at the floor level I will lose so much height in the loft that I won't be able to walk around in there, so I was wondering if it would be recommended to put insulation on both the joists and the rafters?
I was considering putting a vapour barrier and 100mm insulation between the joists, then laying 100mm planks of wood 90 degrees across the original joists at 400mm spacing with another 100mm depth of insulation between those new joists (giving 200mm total on the floor). I was then going to put down loft boards on top.
For the rafters I was going to attach 50mm battens to the existing rafters to increase the depth to 150mm. I was then going to put in 100mm depth of blanket insulation (leaving a gap of 50mm between insulation and felt that's already installed against the tiles). Then I was going to staple a vapour barrier to the battens and some thermal insulation foil roll to reflect any radiated heat back downwards.
My thoughts are that this will keep most heat in the house where it's needed most, any that does escape there will then be kept in the loft to help prevent anything stored up there from freezing.
So my questions are:
- Is this worthwhile insulating both the rafters and the joists?
- Am I likely to introduce issues with damp (or anything else) based on how I was planning to do it?
- Am I likely to have issues with the strength of the loft "floor" with the extra wood and loft panels I'm putting there (There is a supporting wall near the centre of the loft)
Many thanks for your help!
