Insulating Roof
1 Oct 2011
Staffordshire
HI,
I am just insulating the roof on my outhouse, I have pulled the old plasterboard off to reveal the rafters and was going to insulate between them with polystyrene the plasterboard over.
They are only 80mm thick and I need to leave a 50mm gap (I presume to prevent heat loss though conduction). This means I cant use: http://www.wickes.co.uk/polystyrene-rafter-insulation-boards-pk3/invt/210020/?source=123_74
because they are 60mm already.
Should I just cut some thinner polystyrene myself? What plasterboard should I use?
Cheers,
Mick
Have you got the roof height to drop the ceiling a little. You only need 30mm so could add some batons to your rafters.
Genius! Plenty of space to lose. Will get some batons today and stick the rafter insulation in,
I am going to use "thermal plasterboard" on after, any ideas what type to use? How do I fasten it? Nailed to rafters?
Mick
