Insulating solid wall and bay window
23 Nov 2026
Hi all,
I am planning to insulate the solid wall and bay window in the children’s new room, as it is very cold. My plan is to fit insulated plasterboard to the solid wall and bay, using the following product:
IKO Enertherm Insulated PIR Plasterboard, 52.5mm. For the window reveals, I plan to use tile backer board. There are currently no signs of damp, so I intend to fix the boards over the existing plaster using plasterboard adhesive using the dot and dab method.
Is there any benefit to removing the existing plaster and going back to bare brick, other than gaining some space? Would you also insulate the boxed-in section on the ceiling to match the depth of the insulation on the sides?
Any tips or advice on good practice would be much appreciated, as I plan to repeat the same work in our downstairs living room. I also plan to insulate the floor to help keep the room warmer. I have previously installed a bigger radiator, and the difference has been minimal.
Is there any suggestions on alterative productions or using low expanding foam adhesive?
Many thanks
Aky
I’d remove, insulate and replace the ceiling section assuming it’s currently uninsulated flat/pitched roof above it. Put as much loft insulation as poss up there if space allows.
You’re essentially adding 40mm of EPS/PIR to the walls which is going to help but probably not work wonders in the scheme of things … is rest of room insulated above in loft?
I’d use foam to stick the board on as particularly that hexagonal bay will be a right faff and the foam will help fill any voids where you try and mitre the boards up to each other …
Hi all,
Many thanks
Aky
View attachment 427286View attachment 427284
Hi, I am Alex, a landlord based in Birmingham, and I have the same solid wall problem on my own rentals.
On the bay, insulation can go between the studs, but I would not close it up without getting the condensation and vapour side checked first, that is the part that catches people out. On the solid wall, the 100mm PIR and 50mm gap setup from a cavity wall does not transfer directly. For solid walls it is usually external wall insulation, or internal wall insulation, which is disruptive, loses room space, and needs careful detailing around the windows.
What I did on mine was loft and draught proofing first, cheapest first, and then I asked the assessor for the additional list in EPC points order, so I could see what gives the most points for the least money before spending anything big. And keep the evidence for everything, photos, receipts, U-values.
Is the property listed or in a conservation area? That decides a lot, because it rules out external insulation in most cases.
Do those curtains cover the radiator when closed or do you tuck them in? If they cover the rad, tgen shortening the curtains to the windowsill will greatly increase heat from rad into room.
