Insulating
9 Mar 2009
Essex
We are moving into an old house very soon, the house has a seperate double garage with a pitched roof with 3 single rooms attached to it.
The construction is block wall and felt roof.
We want to make this a bit more habitable so we can use it all year round.
My idea was to block up the garage door, fit batterns to the inside of all the exterior walls at 450mm gaps and fill with insulation and then cover with plasterboard.
I am also going to plasterboard out the ceilings, create a loft hatch so I can fill with insulation.
Am either going to felt, shingle or fit lightweight steel tiles to the roof......depending on price.
I do not know what sort of damp proof the building has, what I am afraid of is after doing all this that later on I get the smell of mould and cannot see it as its behind the new plasterboard so have to rip all out looking for it.
What can I do to stop or remedy this.....is there something I can paint on the existing walls etc?
Other questions are:
What insulation to use for walls. Was looking at Kingspan but I think its out of my budget to be honest. What about Rockwall or Polystyrene?
What type of plasterboard for walls and ceilings. Foil backed etc?
Do I need a vapour barrier anywhere.
What would I need to do to the floor?
I really appreciate your help on this.
Fibre wool and polystyrene have the same insulation value but you may find the fibre-wool with a big subsidy from the energy producers.
Whatever type you like, though the foil-backing serves as a vapour-barrier ( tape joints too ) which you do need.
The existing floor or a new floor you want to put in ?
