Insulation requirements for a Cold Flat Roof
7 Feb 2005
Northamptonshire
What is the recommended insulation requirements between the Joist, on a cold flat roof installation.
To prevent condensation, I will be leaving a 50mm air flow gap between decking a insulation.
It's usually around 125 -150 mm Kingspan or equiv.
But - yes - mind the gap.
The Gap will be vented at both ends (front via facia 25mm. Rear into existing pitched roof space.
I was going to use 100mm Kinspan, then top up the 8x2 C16 joists with normal loft lay insulation.
Thanks for all your help.
