Hello. I have an old cottage and we are converting the loft to useable "storage" space (aka non-building regs compliant extra bedroom). We have done the staircase, beams, joists, flooring and Velux.
Next step is studding, insulation and plasterboard. The rafters could take 50mm Kingspan and leave some sort of air gap, but battens probably needed to "thicken" the rafters.
The builder (who is experienced) is happy to use 50mm although he makes the point that it is not building regs compliant. However, I have used 50mm in the roof of the lean-to kitchen and I'm not too impressed with the insulation level.
Please could someone advise me. Is 50mm generally enough and to achieve better ventilation, should the board go on top of the rafters, rather than fitted in between?
If so, what would be the construction technique, including battens and plasterboard? There is limited space so I would prefer not to install too much insulation which encroaches in the living space.
Anyone heard of "superquilt"? - someone recommended this.
Any suggestions on whose prices are keenest on insulation products would be gratefully received.
Thanks very much.
Alistair
Thanks very much.
Alistair
