I'm working on converting an old outbuilding into a couple of rooms. 200 year old building with single stone wall, around 40cm thick.
After much advice Ive built the stud wall, and have bagged a good deal on some bulk insulation that will do the walls and floor. I was planning on 100mm but ended up with 130mm.
However, the PIR boards are non foil. I was gonna go foil, but the deal I got was too good to turn down.
Given the boards don't have foil, would I be best to use a foil based vapur barrier like this;
www.tradestoreonline.co.uk
As opposed to standard green vapour barrier sheets?
Aluminium Foil Membrane - Vapour Barrier and Thermal Insulation - 1.5m x 50m (75 SQ/M) - Trade Store Online
Vapour Barrier and Thermal Insulation. Three-layer aluminium foil, a quality option, used in new-build constructions and renovations. Free Next Day UK Delivery.
