Integrated washing machine carcass door
29 Dec 2017
I've pulled our integrated machine out to adjust the legs as it was vibrating and ever so slightly moving.
The carcass door connects to the actual machine. The door always vibrated when the machine was spinning and was so annoying. As well as this getting the legs level and at the perfect height so that the door is level with the others is tricky.
Can I just disconnect the door from the machine and use normal hinges and leave the integrated free standing in there?
Seems like a design flaw that the door is connected but may offer some stability I suppose.
I doubt if you can do what you suggest, but supplying the make & model might help.
Moved to carpentry forum
