Today I wrote an email to Doncaster Council regarding the lights in the tunnels under the newly constructed Frenchgate Interchange. The problem is that they never seem to work properly. They are supposed to monitor external light levels and equal the light in the tunnel - theres about 5 lighting circuits along both walls of both tunnels, which are turned on and off as appropriate according to external light levels. However, I drive through at night sometimes and they are running full belt, and during the day and its pitch black. Today, one tunnel was dark and the other was full brightness. So I thought i'd queeze some answers out of them!
One of the engineers from DMBC replied to my query.
OK, so are the distribution boards IN the tunnels classed as accessible? I know where he means - about halfway along one wall there is a bunch of panels recessed into the walls. So they had to isolate this elsewhere, instead of isolating the individual circuits fed from this board. The "pavement" in the tunnel is only about a foot wide, so this is understandable that nobody wants to venture into the tunnel!
So why oh why did they put it here?? There's a shopping mall above, why couldn't they build a cupboard up there alongside or behind a shop? There's a bus station alongside this tunnel, why couldnt they put it in there? There's some delivery bays for shops alongside the opposite tunnel . . . I could go on! Honestly, Doncaster council. Is it any wonder you're a laughing stock????
And why does it take 2 cycles to reset the lighting system? One would think such a safety critical application would reset itself straight away. And since is seems they have to isolate this DB every few days, the lights never work properly!
edited to correct "letter" to "email"
In regard to your comment on the tunnel lighting, the 'bright summer day' level in the southbound bore resulted from isolating power to a distribution board in the tunnel from which the CCTV cameras are fed from. This 'sledgehammer to crack a nut approach' was employed as the distribution board cannot be accessed while traffic is running in the tunnel. It was understood that the light detector (photometer) would reset the light circuits after period of time possible 24-36 hours (a couple of ON -OFF cycles), but, as you point out this hasn't happened.
This will be investigated early next week and hopefully restored to normal operation
