Intergas combi no heating. (1)
Do you have a timer/ programmer/ thermostat ,that are all calling for heat ?
If so and boiler will not fire up you need an engineer.
Just sitting idle until I turn hot water tap on then it fires up.the only thing that the wife has said is the hot water seems hotter than normal.
You are going to need an engineer to visit. There are several reasons the boiler isn't firing up ,external controls or within the boiler failure.
Did you top up again/ check the boiler pressure AFTER bleeding the radiator?
Feel the pipes leaving the boiler do they feel hot?
Have you got a bypass installed in the system?
I know nothing about your boiler, find a way to reset it and try seeing if it works. If it doesn't then you might need an engineer to look at the boiler.
You could just try the old turn power off for 30 seconds and then back on again!
Hard boot of the PCB "might" sort it!
Post a photo of your programmer.
Can you try it on "constant", "boost" or "override"?
Hi, yeah check pressure after bleeding towel rail and top of boiler it's at 1.5 bar according to the remote thermostat the heating should be on its got wifi and there's a flame on the display to depict the heating has been requested. Don't know it's got a bypass installed and pipes are cold unless I turn a hot water tap on then 1 pipe gets hot.
Post a pic of the front of your boiler just to confim please
