- Joined
- 28 Nov 2004
- Messages
- 368
- Reaction score
- 58
- Country
I've just helped my son remove a heap of galvanised pipe from his water system. We didn't even know it was there until it started leaking - which would explain why the water occasionally ran a funny colour - rust presumably.
However, once all pipes had been renewed, I tested all outlets, and found a good strong flow on the cold side, but a very poor hot water flow.
The boiler is an Intergas combi 36/30, so should have a good flow rate. My measures revealed a very poor 2litres per minute! The hot taps come on with a burst of pressure, then settle down to a weak flow.
The cold flow at the boiler inlet seems strong, but emerges from the hot outlet far less so.
Also, the boiler will not give hot water on demand if it is on Eco setting. Only when it is on the heat store setting.
My son is going to phone Intergas on Monday to see if they can recommend someone for its second service and also to deal with this issue. But Intergas don't seem to run a service team, they only have recommended installers - and as Tony often says, repairing is a different art to installing. Should my son still take their recommended GSR?
My only thought re this poor flow would be sediment from the galvanised pipe blocking an inlet filter on the boiler - but I don't think there is one. And the heat ex. has big water pipes within it, surely too hard to block substantially?
I know there is a wealth of Intergas knowledge on here and would welcome advice on any of the above.
Many thanks
Many thanks
