Doors are sold in standard sizes & it’s normal procedure to trim these to fit so you will probably have to cut them down or get someone to cut them down for you. With solid wood or composite doors, it shouldn’t be a problem to trim the height by 40mm but the cheap, panel doors don’t have enough timber in them to trim by that amount; although there are ways around it though!
