Intermittent Boiler fault / Possible PCB faulty?
17 Sep 2012
Cambridgeshire
Hi all, I have searched for a problem similar but can't seem to find one.
My Glo Worm Ultimate has developed a fault where it won't always fire up. I have checked for loose wires and they are all fine. If I tap the PCB the orange LED on 1. switch live/fuse part of the board illuminate and then it's all systems go.If i tap it again it will usually swith back off, and so on.
Sometimes when i tap it the LED just iluminates very feintly and will not move on to LED 2 but then with another tap it usually kicks in.
I am obviously thinking it's the PCB at fault but could it be something else? If it is the PCB is it repairable usually as they are pretty expensive to replace.
I can still get heating and hot water but am having to leave the electronics exposed to keep giving it a tap.
Hope someone is able to advise, thanks in advance!
