Hi All
Was wondering if you could help? Have had a power shower problem for some time now and was browsing this forum to try and fix it, eventually resolved the problem to the following.
House has 4 power showers, 3 are perfect! However 1 operates normally on cold but as you gradually increase the temperature the water strength seems to fall off; the water slows down to a 'mild rain' and then spurts up again to near full strength - cycles every 5-7 seven seconds - and the pump is cutting in/out in tandem.
It's an upstairs shower as is one of the working ones. I've tried switching shower heads but this makes no difference.
Please can you help?
