    Dismiss Notice
Internal condensation problem
Discussion in 'Building' started by robsykes, 9 Oct 2011.
  1. robsykes
    robsykes
    9 Oct 2011
    5
    Thanks Received:
    Derbyshire
    Country:
    Evening all
    First post here so apologies if my query is in the wrong forum.
    I'm becoming concerned about condensation on two interior walls in my house. The interior walls are damp to the touch and they are either side of a corner and both walls have an exterior walls on the outside.
    The problem is on both the ground floor and the first floor.
    On the ground floor, the problem is behind a door that closes off the kitchen at the foot of the stairs from the staircase itself.
    On the first floor the room affected is a bathroom. The condensation is clearly visible here as it has 'bleached' the paint. There is no fan in the bathroom so whenever we use the bath or shower we open the window to allow air to circulate.
    On the outside, I've noticed that the bricks that match up to the areas that have condensation inside look 'damp'. At ground level on the outside the cement between a few of the exterior bricks is a little 'crumbly' and the traditional stone bricks have yellowed a little.
    Hope this paints a sufficiently clear picture of the problem - would be happy to give more details if required.
    With winter coming I'm keen to remedy the problem asap but without spending money needlessly so any advice from people on this site would be very gratefully received.
    Many thanks
    Rob
  2. hotrod
    hotrod
    26 Dec 2007
    1,162
    Thanks Received:
    110
    Country:
    Condensation and kitchen, bathroom + no fan is to be expected. You need to get some ventilation going. Have you got any pictures - internal and external?
  3. Sponsored Links
  4. JohnD
    JohnD
    15 Nov 2005
    73,458
    Thanks Received:
    4,230
    Crossgates, Europe
    Country:
    Cook Islands
  5. Nige F
    Nige F
    28 Jun 2005
    21,197
    Thanks Received:
    1,740
    Country:
    You remind me of George Dixon ;) You really need an extractor in the bathroom - as do I , but I`ve not got round to it yet :oops: . Unfortunately an open window will not draw air out - it will just blow in and spread the moist air round the house :idea: . Welcome to the DiyNot forums :)
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
