So, you think more like in this second version of the diagram, then?
One query with that - the guidance I've read online seems to suggest that the part of the cavity wall that is below ground should have its cavity filled with a sand and cement mix up to ground level. (I had shown that as a grey box in my picture.) How should I handle that if I have the DPM crossing the cavity below ground level?
One other query - should I seek to fix the DPM to the inner side of the outer wall, or would it be OK hanging loose in the cavity, where it might flap anywhere between the inside of the outer wall and the outside of the inner wall?
Thanks,
Jamse
Thanks,
Jamse
