I have a 1905 single brick skin semi and want to insulate the inside of the non-party external walls. I realise this could be a big job so plan to try one room and learn from that.
My plan is to use an insulated plasterboard (e.g. Kooltherm K17) with a dab application direct to the current plaster - I will follow manu's directions. Will likely use 72mm thickness board. My questions are:
1. Should I remove the current plaster? - a lot of work but would presumably give me 3/4 in extra to play with around the window trim - luckily no door on this first wall.
2. The window surround protrudes 1 inch and the cill 2 inches from the wall so even with removing the plaster I will need to extend these. How is it best done without replacing whole cill?
3. Should I remove the window reveals to insulate them - probably to avoid heat bridging? There is enough space around the inside of the window to accomodate the insulation and replace the wooden reveal if i do this.
Typically I jump into dyi jobs and then find the problems so any help gratefully appreciated.
Thanks Martin
Thanks Martin
