New home, there are 3 of these extractors, I took the cover off 1 cant see any time delay adjustment, is that why they are cheap, or is there something I just cant find.?
If it's the one im thinking of you have to remove the front plate and there is a small hole into which you insert a small screwdriver or allen key but I can't rememeber which one or where.
OK thanks I will have a look in more detail.
Sorted, top left under cover is adjustment.
Product Description:
The Intervent NVF100T 100mm (4") bathroom/toilet extractor fan by Manrose has an integrated adjustable timer and is designed for wall or ceiling mounting. Quiet and efficient, the units are all manufactured using high ABS thermoplastics for strength and durability, aesthetics and easy cleaning. Power is provided by a single phase induction motor with pre-oiled bearings for a long, maintenance- free life.
•Extract rate of 85m³/hr, 23 litres per second
•Wall/ceiling fixing through 4" Ø flexible or rigid pipes or Manrose low profile, flat channel ducting systems.
•Single phase consuming 14w, 220-240V - AC. 50Hz
•Suitable for use in bathrooms & toilets
•Pre oiled bearings for long and maintenance-free life
It so so annoying to read those figures when in most intallations they cannot achieve that rate of extraction.
With the fan on a test bench in free air that may well be the "extract" rate. In reality the extracted air has to travel under the bath room door, through a ceiling vent and then, expanded by the warmth of the bathroom and loaded with water vapour has to be pushed along a twisty often corrogated duct to a outlet on a wall where wind pressure is opposing the flow of air coming out of outlet.
