I have a fairly modern house with underfloor heating throughout. All plastic pipes, no radiators or metal parts, other than the parts in the vaillant ecotec plus 630 boiler. It has a Magnaclean filter fitted, which I check at least twice a year. Every time I do this there is a build up of metallic particles, some large enough to see. Never a lot but always some. This deposit has also caused the F75 fault to come up 3 times in 4 years. Each time an engineer from Vaillant has changed a part that has been clogged with metallic/magnetic particles. I am totally mystified as to where these particles are coming from, as the system has no metal components, other than the boiler components and perhaps pump parts and expansion tanks. I cannot imaging it is in the mains water supplied by Affinity water.
I would be grateful if anyone has any ideas, as the F75 fault (pump or low pressure) has come up again.
