Is fitting a manifold straight forward? if so any recommendations on the make / Type or guides?
I can't see anything that detailed on youtube on a full installation.
I've replaced the timber floor in my kitchen, and as part of that put in 15mm JG Pex barrier pipe for the first zone (Have access to underneath - the boiler room is here - unvented cylinder / boiler) eventually there will be other zones as the house is refurbished.
The plumber who installed the entire boiler system last year who i would like to use is booked up for a couple of months and its getting cold!
If it is best left to the plumber, approx area where the pipe work is, is 15m2, if the ufh pipe is hooked into the central heating loop will it cope with no manifold / pump short term?
