I have a vaillant system boiler of 18kwh size and even after it's on for more than an hour, the flow temperature shown on the front panel is at around 48c with gas burning very slowly whilst whole house is cold.
Every few minutes (not timed the interval), gas burning intensity increases which pushes flow temperature very quickly to 70-75c (the max limit set) and it comes down back to 48c within seconds.
Then after a couple of minutes, the regular flow temperature rises by 1c to 49 and repeat the same cycle as above. But even after continuously running boiler for several hours, I don't see boiler flow temperature reaching to above 55ish C
Practically, after running heating for 2 hours, radiators are just warm when the actual flow temperature settings should allow it to stay at 75c to make them hot enough to heat up the house.
Is this a normal way of functioning of vaillant boiler or you think there's some fault?
