- Joined
- 5 May 2020
- Messages
- 5
- Reaction score
- 0
- Country
It is a new build house just under 2 years old, so it is all metal stud framed walls. No partition walls are solid other than the semi-detached split and the external facing walls, so based on that I have no idea what is load bearing and was is not. Recently, with all the time spent at home, and what with the work in question being in the downstairs loo, I have had a lot of time to be pondering some work we had done ages ago, which was a water pipe splitting and sharing with a water dispensing fridge!
It just occurred to me the other day that the tradesman we had out must have drilled through one of the metal studs. Based on the lack of solid walls, it made me wonder if that perhaps some of the stud walls are load bearing? If that is the case, is it an issue that a metal stud was drilled through? Based on the size of the hole and the size of the studs it would be quite a significant hole through one of the studs.
I have got a picture of the hole in question, along with photos taken before the house was completed showing what is in the wall and what the joists look like above the wall, seen here:
The reason I am even thinking about it after all this time, is because we have some slightly creaky floorboards on the upstairs landing (one of which is above that wall) and a small gap between the top of the stair case and the landing next to it. I always attributed this to the house settling, but it got me wondering if it could possibly be linked to this stud having been drilled?
