is it OK to leave heaters off all year round?
15 Nov 2019
Hello.
I have 2 rooms where I do not spend much time in... one of them is like a storage room. and other is like a room where I keep my wet laundry for drying (leaving window slighlty open all the time).
both of the rooms have gas based heaters (central heating based). to save gas I am thinking to keep these heaters off all year round. is it a good idea?
I wonder, would it not affect pipes in a negative way? and also would it not affect carpets, walls (especially in the room where wet laundry is kept) if there was no heating all year round all the time?
thank you for any comments.
You should have at least a little background heating to keep the cold and damp away, but it won't adversely affect the system if you do have them turned off
Yes it will - wet laundry airing in an unheated/poorly ventilated room is a recipe for damp and mould.
this is what I suspected... is there any way to avoid it without turning the heater on? like if the window was left open all the time or something like that.
Leaving the window open all the time would make the rest of the house colder if the room door were open too. Closing the room door could prevent adequate ventilation of the room. Catch 22.
Ventilation needed to avoid damp etc in the room would need air to flow through the room, an open window is only one side of that flow. You would probably just create draughts in your house.
As @muggles mentions, it's alway a good idea to keep at least a little heat within a room, doesn't need much
The radiator in the main bedroom is off all year round, but the bedroom door is left open always -enough heat circulates during the day and evening for the bedroom to be warm enough at bedtime. I cant stand a hot bedroom -small window open overnight every day of year.
Try it and see if it gets damp.
The missus uses one of our bedrooms as a drying room. We have one of those electrically heated airers in there plus it has windows on two walls which are always on vent. I keep shutting the bloody door because it feels colder when I go upstairs and she keeps opening it. Constant battle but we have no dampness or mould issues.
thank you for the comments. I dont wanna tart a new thread, so I thought I would ask one more question related to the central heating. is it a good idea to turn the boiler off when leaving the house and turn it on when coming back home? I mean to keep it on only while being at home, cause I do not see a point of heating the house while Im away for 9 hours.
setting the program or turning the boiler on/off at certain times is one and the same thing :) anyway is it a good idea to have the boiler on and off, would it save eenergy? or would it have an adverse effect on the energy consumption cause once you turn it off and then on again it needs to work hard to get the temp right all the way up from the bottom.
also, I don't really understand. if humidy causes problems in regular rooms, whats about the bathroom? it is always humid there, does it mean heater needs to be on all year round in the bathroom?
Bathrooms usually have purpose made/forced ventilation or an open window to be opened when you have a bath/shower, that is then closed/turned off once the steam/heat dissipates. The window shouldn't be left open all the time, then the door open to keep air circulating with the rest of the house. The bathroom wouldn't normally have lots of soft furnishings/carpets either that will hold the moisture keeping it humid.
Yes it's better for the boiler, never mind saving energy, to have a boiler running rather than regularly going hot/cold/hot. How much energy is saved though would ultimately be down to size of system.
There is no doubt about it turning the boiler off when you don’t need it saves energy. Yes it works harder to heat up again but overall you save.
The energy provided by your boiler replaces the heat lost through your walls etc which is proportional to the difference in temperature between the inside and outside. For any period that difference is lower represents an energy saving.
