Hi
Recently had a new boiler fitted - Vaillant Ecotec 937plus and the hot water flow rate seems crap (though probably a coincidence with the new boiler rather than it being the cause). I can not run the shower and any other tap in the house without the shower cutting off. Or any combination of hot taps for that matter - i.e hot tap in kitchen and bathroom on would cause a dribble from both.
As suggested elsewhere, I put a bucket under the kitchen tap and ran it for exactly 15 seconds - measured the volume of water passed and multiplied by 4 to get the /min rate. The hot came out at slightly over 10 l/min. Thought this was rubbish as according to the boiler lit. it can handle up to 20 l/min. Did the same on the cold water - mains fed, same tap - and got 14 l/min. I have nothing to measure the pressure with.
The house is newish - 10 years so all new (ish) pipework , and is on a new estate, so hopefully decent pipes to estate - but who knows!
I don't know what kind of flow rate I should be expecting on average and whether it will vary signifcantly during the day - i.e do I have to measure it at various times throughout the day to get an average?
Does the above flow rate sound ok, or do I need to hastle Untied Utilities - or will they fob me off?
Cheers
Cheers
