No doubt this has been asked plenty of times, please excuse my ignorance in not finding a suitable thread on this so far.
Vented central heating and hot water system, Y plan, Grundfos Selectric 15-50 circulating pump....
Boiler (glow worm) making some knocking and banging noises.
My plan was to: Drain down and introduce Sentinel X800 Jetflo directly into the system, run for an hour or so, then drain down again, before refilling and adding Sentinel X200 descaler and running that for a couple of weeks (I know it may be run indefinitely), then drain once again, refill and add a standard inhibitor, such as X100.
However, after intially firing, with the cleanser added, the boiler locked out, and I noticed that whilst there was heat in the initial 22mm length of boiler flow pipework, as it progressed closer to the pump, the pipe got colder, with no sign of heat before or after the pump. Pump body running hot, but cold pipework either side of it. Am I correct in assuming pump failure? It's whirring, but ideally I'd like tangible evidence it's pumping, or not, before I go and replace it.
System was powerflushed about 6 years ago.
Thanks for any helpful suggestions.
Mike
Mike
