- Joined
- 21 Nov 2020
- Messages
- 3
- Reaction score
- 0
- Country
Hi all,
I have what I think is called an "S Plan+" central heating system. That is there are separate zone valves for DHW and each heating "circuit". It was fitted around 14 years ago when my house was renovated. There is UFH in kitchen, rads elsewhere; it's a 3 storey large house.
The manifold, pump etc for the UFH are situated about 6m away from my boiler, both of which are in the basement of my house. The UFH is for a large kitchen/breakfast room approx 10m x 6m plus a utility room.
The on/off times for the UFH as well as DHW and rads circuit are controlled by a Horstmann 3 channel programmer sited next to the boiler. This sets the on-off times for each circuit switching on the boiler and the DHW and rad zone valves. As far as I can tell the (wired) thermostat for the UFH only controls the UFH zone valve - that is to say there is no wire from the UFH 'wiring centre' to the boiler.
Since the kitchen floor (the one with UFH) is stone tiled, I was advised on installation to keep the UFH 'channel' of the programmer on permanently (due to the thermal latency in the stone floor I guess).
ISTM that with my boiler on 24/7 I am permantly heating the 6m flow & return pipe from boiler to UFH manifold & pump (in my cold basement) even when the UFH is up to temperature. Yes, I know the zone valve will be closed in these circs but none the less it doesnt seem very efficient to me - am I missing something here???
Likewise I have no room stats but TRVs on all radiators. With the Horstmann 3-channel controller only operating zone valve and switching the boiler on or off according to the times set, my boiler is running whenever any of these channels are 'on' is it not? Obviously the boiler cuts out when it is 'up to temperature' but thats only a boiler decision, its not affected by UFH or radiator / room temperature. The boiler is a Keston C40 btw.
Just wondering if this sort of arrangement is normal?
Thanks for any advice - I am looking to replace all heating controls in my house with something 'smart' but I'd like to understand a little more about what I actually have right now.
