I am in the process of having an extension built that incorporates UFH totaling 75 sq meters set into 5 zones. This was installed a couple of weeks ago on top of 75mm Kingspan then screeded over with 80mm. The plumber pressure tested the UFH zones and left the system pressurized. The room where this was installed was open to the elements as the glazing has not been installed. Since this time we have had some severe frosts and on Wednesday this week the main contractor spotted that the UFH pressure had fallen to zero. They topped it back up and noticed pretty much straight away that water was seeping through screed in two places within the same zone. The chopped holes in the screed and found the split pipes and replaced them with new sections jointed with some type of joint supplied by the supplier. They then re screeded the holes.
I found out about this yesterday when I returned from working away. The affected pipe was returned to the suppliers for the attention of the company rep who said immediately that the damage was due to frost. I also noticed that two of the pipes at the manifold had prominent bulges just below where they connect into the manifold.
Can anybody advise me what is best course of remedial action as I now do not think this installation can have the same integrity as a brand new system out the box that has not been subject to frost. Whilst I do not want the delays associated with ripping up 10 tonnes of screed and having to re do the installation (builders cost and time) I do not trust them just doing a pressure test. They suggest pumping up to 3 bar and checking for leaks.
Over to you guys for advice and guidance. FYI, I have a very good relationship with the main contractor.
