D
Dazed14
Hi
I've recently had a Vaillant 831 installed and while it seems to be working fine I'm not too sure if it's working as it should, I'll explain.
When the system is cold from overnight, the bolier fires up, burner goes all the way up and then immediately drops to minimum burner level. After 1.5-2.0mins the burner fires up to around 75-80%.
If the heating cycle is interrupted at all, like the water being run or the programmer turning off and on, then when it fires back up it does the same thing (fires up and drops to minium) but then takes around 6mins to fire up fully. It then has this (lag) every time it fires down-up.
Does that seem right? I've never had a condensing boiler before so maybe this is how they work. Would just like to know for sure.
