is the joist weakened?
  • Thread starter Thread starter imamartian
  • Start date Start date
I
imamartian
if i have a 100mm x 47mm joist, is there a calculation to work out it's strength? or what weight it can support?
And what if i drill a 10mm hole in the middle of that joist, do i compromise it's strength?
and if i drill two 12.5mm holes above each other, have i reduced the strength of the joist to that of a 50mm joist?
and finally, if i drill one 10mm hole and put a 10mm bolt through, can i expect the strength of the joist to be unaffected?
what is it you are trying to achieve it may be easier for an answer.
i thnik your question is well above that of DIY level, thats more something that a structural engineer may know about.
ok, to bring it back to a DIY question.... what's the biggest hole i should drill in a 4" joist to run a cable through?
My original question was aimed at the purist.... :roll: lol sorry
i wouldn't personaly drill any hole in a 4" joist? where is this joist located? whats the span? if its only one cable then drill the smallest possible without it being too tight.
25mm hole drilled at the joist centreline and located between 0.25 and 0.4 times the span from the support. Multiple holes should not be less than 3 diameters (centre to centre) apart.
Yes, it's a straightforward number-crunch
No
No, but there are rules for positions and spacing of holes and slots, generally totally ignored by sparkies and plumbers.
Yes
