Is there a Log/Multi fuel fire with outside air supply?
15 Feb 2009
Norfolkshire
Hi, we are at the planning stage with a new build & wanted to install a multi fuel log fire with water heating facility’s, that draws its air from outside.
The main reason for this, is there will also be a heat recovery ventilation system being installed & didn’t want the log fire sucking the recovered heat up the chimney.
Has anyone seen a fire like this? Or has anyone got some idea’s.
Chris.[/b]
Just omit the room with the stove from the ventilation system, won't need it if it's heating the room.
