Is there a one way valve for washing machine outlet?
1 Feb 2006
Moray
Every so often I get some water running back into my washing machine from the sink. Does anyone know if there is a one way valve available that I can put at the end of the hose, where it connects to the sink?
I would prefer the valve to go here as the washing machine is fitted into the kitchen units, so it would be the easiest option.
Many thanks
yes - non return valves are available but the problem suggests that your waste pipework may be partially blocked - check that the trap is clear. Try raising the waste hose from the washing machine before it joins the sink waste - form an inverted U
Thanks for the quick reply - I'll check out the sink trap, etc and stick one of these valves on as an extra precaution :)
Cheers :)
