Is this an attempt at a Rip-Off ???
8 Jan 2007
Gilberdyke
Hi Lads,
After deciding that it wouldn't be in my best interest to attempt to fit a new boiler myself, I decided to call a couple of local fitters to get some quotes for replacing my old Myson Central Heating Boiler.
One guy came down today while I was at work, our lass showed him to the boiler position & after having a quick look at the original pipework, he stated that he would have to change it quite a lot due to it being non-standard ??? He said he would let me "Think About It" & to ring him back for a quote ???? - Sounds WELL dodgy to me - am I right ?
Our lass said that he was referring to a link-pipe that existed between the feed & return pipes, underneath the boiler ( see pic. )
I've found out from the house paperwork that the CH was fitted about 20 years ago. Have the rules changed now so that that pipe has to be removed or summat ? The system has an overflow/fill tank in the loft, so I presume it is classed as fully pumped/vented yes ? I was guessing that the pipe may be something to aid with filling/draining or summat ?
Also, the boiler flue exits directly through the wall from the back of the boiler ( a balanced flue I presume ? ) with no ductwork needed. Most of the boiler installations I seem to see atm have a separate pipe leading from the top of the boiler case. Can the old type of direct flue boilers still be bought ? It would save me a bit on having to do more brickwork if I could just use the existing flue-hole on the new boiler, as I would be able to make-good any alterations that the fitter had to make to the opening myself, once he had finished the work to the boiler.
I am still waiting for a response from the other fitters but if any of yooz guys could point me in the right direction as to whether this work would actually be required would help a lot.
TIA-Shaky
That looks like a bypass (between flow/return) on the central heating circuit, If your heating enginner thinks its complex then he cant have much of a clue.
Get a few quotes and get him to explain his plans.
Al
The pipe inquestion is a by-pass and will need modifying as will the pipework around the boiler.
Certainly not a major repipe, but saying that there could be issues that need sorting, e.g. the cold feed and vent etc.
Whatever or whoever does the job a proper powerflush is essential on an old system.
Also consider the Magnaclean filter
Nice unit 3 though :lol:
How is that still running. Do you only run your system once a year :lol: :D
Non - Expert opinion,
As said that is the bypass, building regs require an AUTOMATIC bypass and not a 'gated' one (which you have) though the provision of the auto bypass is down to the specific instructions with the new boiler and the system layout S/Y-plan etc....(y plan 'generally' dont require a bypass). But either way its not really gonna effect the price. is it fully pumped at the moment? (has the plumber mentinoned room stat and thermostatic radiator valves also).
I take it from that quip that they aren't exactly renowned for reliability ? :lol: As far as I know, it's the original pump that was fitted when the CH was installed in 1985. According to the original home-owner, he'd had no extra work done to the CH since he had it fitted, looks like he's been a lucky bloke then aye :shock:
And get some quotes from decorators! Have you no shame?
Let's just say I'm in the process of re-modelling the bedroom  8) At present there is no plaster on the walls, just re-floored with chipboard & am in the process of re-building the stud wall back up !
<b><i>layout S/Y-plan etc</i></b>
<b><i>is it fully pumped at the moment? </i></b>
<b><i>room stat and thermostatic radiator valves </i></b>also).
1.Hmmm....How do I tell what is Y & what is S plan ?
2.All I know is that there is the pump fitted ( on the photo ), that works every time the CH turns on. When the heat is reached, both the Boiler & the Pump switch off. ( This happens way too often as I had to turn the Boiler Thermostat down to the minimum setting, otherwise you could hear the water boiling in the unit itself, then it used to switch off & EVERYTHING shut down - gas as well !! - I presume this is the overheat cut-out doing it's job. I got well ****ed-off with running upstairs every half-hour to re-ignite the pilot. - Hence the need forra new boiler :))
3.There is a room stat fitted already, although no trv's on any of the radiators.
fitz1 said:
me thinks man came , saw chipboard floor and legged it. :lol:
He would have definitely "Legged It" if he came down before I re-did the floor. I nearly went through the damn thing myself - floorboards were rotten as hell. God knows what the previous owner had been doing to miss that his floor was rotting. :shock:
It's all been replaced with spanking new treated 8'x2' chip. I'm gonna be carpeting the bedroom anyway, so I couldn't see the point of spending a fortune on floorboards when caberboard is much cheaper. ( Especially when most of my work for BT is on new housing estates & there are always generous Site Foremen who don't mind the odd couple going astray :wink:
