- Joined
- 7 Apr 2024
- Messages
- 4
- Reaction score
- 0
- Country
Builder & plasterer have finished re-boarding & skimming our entire bungalow, glossy smooth finish which we thought was carefully applied and considered. Allowed four weeks to dry before beginning to paint.
Gave the ceilings a light sanding before painting, mist coat and two top coats of Tikkurila anti reflex with rollers and brushes.
Went back to the property today and found lots of ripples / uneven layers matching the direction the plaster was applied. I know sunlight can draw out even the tiniest imperfections but we were quite upset that our entire ceiling looked like it had stretch marks!! We didn't spot these during our painting sessions as we were only able
to paint in the evenings due to work but today the imperfections are clear as day.
These pictures are from two separate rooms, suggesting every ceiling is like this. We haven't tested the walls yet but we suspect after some investigation that the same issue persists.
Does anyone recognise this issue? Is this a fault with the plastering, a fault with the painting or something relating to humidity / drying times?
This is how the plastered room looked before painting.
We're thinking of calling the building team and asking them to either re-skim and level correctly or having it sanded down thoroughly and repainting. Can anyone suggest if this is a sensible idea, or if we're expecting too much from the ceiling not to be perfectly smooth?
Thank you!!
Thank you!!
