this is in a rental - would this pass a safety certificate?
Is that just paint (and/or plaster) on an exposed bit of (intact) cable? If the exposed bit of cable is intact (no tears, holes etc.!), it's probably both legal and 'safe', albeit obviously very shoddy!this is in a rental - would this pass a safety certificate?
How did they have enough cable to do that? - how far below the old socket is the new one?they have taken the feed from the socket in the photo, cut it off and then run the cable over the top and down to a new socket.. very odd
Well, if that's what they've done, then to answer your initial question .... the "connection block wrapped with insulation tape" is neither 'safe' nor compliant with the Wiring Regulations (BS7671), and arguably is not even 'legal' (compliant with Part P of the Building Regulations, which require that electrical work does not pose a risk of injury).from what i can see, they have a cable running down the wall to the old socket, they have cut this off 4 inches above and joined (using a white connection block wrapped with insulation tape) and run a new (old) cable down the wall over the socket to the new one 2 ft below the old one externally.
Fair enough.didnt think so, might have to have a word with the owner as its a medium term holiday rental!
