By comparison to other radiators in the house, I'm guessing it is - but I wanted to check with you guys.
My attention was drawn to this after a leak coming from the top of one of the valves, and then I realised that something else is amiss. This is what I have.
Left valve (OK):
Right valve:
The right valve should look like the left one, is that correct? With a protruding stem that allows the internal-most part of the valve assembly to rise up and down when turned. The brass nut on the top of the right valve turns but then of course just releases a lot of water from the pipe.
The funny thing is that I isolated and removed this radiator myself about eight months ago and so must have tightened down this broken right valve somehow. Perhaps it got damaged during later work in the room.
On other radiators in my house both valves look like the left one above.
If I'm right in thinking that the right valve is damaged here then I'll go ahead and replace it.
Thanks,
Left valve (OK):
Right valve:
Thanks,
