Hi
About to install a solid oak floor.
Pulled up the carpet to reveal a solid concrete floor.
The property was built around 1976, and it is 4" below sea level.
Around the whole property (chalet bungalow) is a wide concrete skirt,
which does flood on a heavy downpour (about 2" to 3") because the
ground around the skirt is mainly sand and it takes a while for the
water to sink away.
The property is a cavity wall system. Regular 9" bricks and very dark
grey blocks which although they turn to very fine powder when drilled,
do in fact holds things like radiators.
We have been here 6 years, and have not detected or smelt any
damp whatsoever.
MY QUESTION;
On the wall that is adjacent to the outside, there is a 10mm gap
between the solid concrete floor and the block work.
Is this some form of Damp Course?
i.e. is the gap there to stop damp crossing between the
block work and the floor?
There is a regular damp proof course inserted in the brickwork on
the outside, but as far as we can tell (after drilling down some way)
we cannot find a DPM within the concrete floor itself.
To be on the safe side I'll be laying a DPM (thick plastic sheet)
between the battens and the floor before laying the wood floor.
I would like to fill this 10mm gap - to help stop draughts etc.,
but I'm concerned that if I do I might be casing a lot of problems
down the line.
Should I fill this gap - or leave well alone?
Any thought or suggestions would really be appreciated.
Many thanks in advance.
Stephen
water to sink away.
damp whatsoever.
MY QUESTION;
down the line.
Stephen
